Solved VPN to Hosted 3CX?
vgarg
Hello I am planning to put FXO Gateway as 5 POTS cannot be ported to SIP. For Hosted 3cx, i believe i need VPN as Gateway device has to be on the same LAN. How do i establish VPN to Hosted 3CX? Thanks
Hello @vgara,
you cannot configure a VPN on a hosted by 3CX instance. Assuming that you want to use some analog phones while hosted with us, this is possible with an FXS Gateway and the 3CX SBC.
Actually these POTS are Hospital extension, with my current system I am using Patton gateway and any 4 digit dialing goes through this gateway and reaches any extension in hospital making it very convenient. I don't need to use analog phones
Rhameez
