- Joined
- Oct 5, 2021
- Messages
- 48
- Reaction score
- 4
This is a stun setup.
As the title says. The odd think is, I've reset the W60b back to factory and re-provisioned it. It registers itself just fine. However, activity log shows "Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings"
Odd since I just re-provisioned from scratch.
Eventually, authentication fails 5 times and the WAN IP is blacklisted.
Looking at 'Accounts' on the W60b, it says it's registered. I've tried copy/pasting the extension password from 3cx into the account registration page, but that doesn't help.
Only solution I've found is to white-list the WAN IP of the phone. Authentication failures are still showing in the logs.
3CX version is 18 update 6
