Solved W60B Phone - DECT Phone - Parked Calls
Rick Fuller
I have a few W60B phones (DECT) that show the 5 Parked BLF keys in the admin console, but are not on the phone itself. Is there a setting I am missing to allow those to show up? Thank You in advance,
There is not a lot of space on that handset for individual BLF keys, unless they have a code to access each.
This manual, (point 4.4.2) says that BLF is not actually supported.
https://www.manualslib.com/manual/1411077/Yealink-W60b.html?page=23
Unless there is a firmware update that supports this, you might consider using a dummy extension forwarded to an SPx, for access to parking.
Reactions: Rick Fuller
younis sadikot
