Solved Wallboard
Hajjaj
Forum User
Hi for all
I need your support regarding wall board since the current results is cumulative while I need it to re-new on daily basis
You can reset your Queue stats daily if you wish.
Go to the management console, find your queue, under advanced you will now see:
11741
Thanks for your support now i try it and the results is reset to be on daily basis
Reactions: JohnS_3CX
gmacinit
