Want to install on Win 10 Pro Machine
MGindia
Dear Sir/Madam,
We would like to install 3cx on Win 10 Pro machine for internal Office / whole building purposes, where Android mobiles & 3cx apps are running on the same intranet (internal) Wi-Fi network instead of INTERNET so in this case, there is no use of the internet.
BUT in rare cases is it possible to convert the same license/IP settings to run on INTERNET? If yes then do I need to create the whole USERS again?
I think STANDARD LICENSE would work as we don't need any extra features as calls/msg/chat are already included in STANDARD ONE.
B.regd
Mayank Gupta
Reactions: MGindia
Thank you for your reply sir :)
So only for license activating, INTERNET is required & after that on LOCAL IP whole software + mobile apps would run without internet, just like internal PBX on the same NETWORK. Mobile should also run on the same LOCAL IP Wi-Fi / AP to access without any INTERNET/MOBILE DATA?
Will you deploy for us on a chargeable basis if giving you access via TEAMVIEWER on using a 500mbps broadband internet line?
No need of custom FQDN?
STANDARD License would be ok for us?
How much is your service charge & time taking?
You are located in US or in another country?
B.regd
B.regards
Mayank Gupta
3CX has a call home function, so it will contact the licensing servers to validate your license - you can not totally block internet access for the 3cx server.
What you can do, is allow internet access from the 3cx server and block 3cx incoming ports - https://www.3cx.com/docs/manual/firewall-router-configuration/
