Wants to connect 3CX pbx to Siemens HiPath 3550
Chetan Chavan
I have install 3CX software on my system and now i want to connect 3CX pbx to Siemens EPABX HiPath 3550.
Kindly give some idea, how it will possible?
I have a requirement where 3CX and Siemens HiPath 3550 running both together. Is this possible?
CC
If the Siemens PBX is able to register to a VoIP provider, then you can have it do so, to a Bridge trunk, in 3CX. As far as running both "together", you may encounter some limitations beyond passing calls back and forth. It depends on what you are expecting to be able to do. The Siemens will have to be capable of creating a dialplan, that will send the correct digits to 3CX.
https://www.3cx.com/docs/
Wecare_ITA
