Way to create permanent conference bridges/rooms?
bignetonline
Previously I have used FreePBX and it has the ability to have permanent conference rooms that people can dial into whenever they want, without having to setup a conference. In 3CX, I can only figure out how to make a timed conference room that stops after a period of time. Is there a way to make a permanent conference room?
PS: I would have posted this in the "Ideas" forum, but it says I have insufficient privileges to do so.
If I am understanding your question, yes you can, see the link below.
Just be aware that you will have to first open the bridge before others can call in. We normally do this about 5 to 10 mins before the conference is set to take place.
https://www.3cx.com/blog/voip-howto/create-conference-using-desk-phone/
Thank you for the response, while this is good to know, it doesn't appear to create a permanent conference bridge, as I think the bridge shuts down when the call is complete.
I believe I can accomplish a permanent conference bridge by setting one up in the user web UI for sometime way in the future. The bridge actually gets created instantly, and is ready for use until the specified date. If you set it years in advance, this should work just fine.
M_R
