- Joined
- Jan 11, 2016
- Messages
- 178
- Reaction score
- 10
Carrying on from this post:
https://www.3cx.com/community/threads/web-browsing-into-stun-phones.57096/
I've had a play and I'm struggling.
I'm using a Zyxel VMG8924-B10A router and I've port forwarded using the following rule:
Source Port / Destination Port / Destination IP Address / Type
7000 / 7000 / 192.168.1.10 / TCP
I changed the HTTPS port on the Yealink phone from 443 to 7000.
First problem is locally I cannot web browse to 192.168.1.10:7000, it refuses to connect, reverts to http and then I can get in.
No access using the public IP of the router 123.123.123.123:7000
I've tried changing the HTTP port from 80 to 7000 and have the same problem, no connection.
I temporarily changed the firewall setting on the router to allow WAN to LAN but it still fails to connect.
I will try to replicate it in the office and set up a mirror on the LAN port to capture the traffic and see where the issue is but is there anything obviously wrong that you can see.
