web camera (http vs https)
Jake D
How do we make our webclient use https instead of http? Our webmeeting/web camera isn't working and I'm guessing it is due to the web address for our webclient being http.
Thanks!
The web client I presume is local to the PBX and using port 5000 correct ? I am not sure of a way to force this behavior and I am sure this has been asked before.
Perhaps try checking the "parameters" section under Settings to see if there is an option.
I thought the web client was https only? If I try to use http I get a redirect to https.
WebMeeting won't work if you're connecting to the WebClient via HTTP. You'll need to connect via HTTPS. A warning is shown if you try to do this which says HTTPS must be used.
Reactions: Lee Cramman
Aroosa
