- Joined
- Nov 23, 2021
- Messages
- 6
- Reaction score
- 0
Hello all,
I have installed V18 softphone. I can see that version is using voice codec OPUS for internal call.
My issue:
When i do call external all works fine, but when i do internal calls, between user inside 3CX i have background noise (like tok, tok, tok, each more or less 20 seconds), i don´t know what is it, so i can do eliminate it?
note: Both calls (external and internal) cross a Fortigate firewall, but i only have problem in internals calls.
Questions for my LAB:
How can change it?
Is it possible to have uses with codec g711 e others with codec opus?
The 3CX transcoding works fine?
In ancient version was possible to have one codec for internal calls e other for externals call. It is possible in V18 ?
--- If yes, how can do it ?
Many thanks,
HNR
My issue:
How can change it?
Many thanks,
HNR
