Web Conferencing info
Amphibian
Hey Team,
Does anyone have or know of a manual for the use of the Web Conference. Am in need of info on how to stream a live video feed during a web conference. Have been trying to make it work with streaming from ZoneMinder but can't seem to get it working.
Any suggestion would be great.
Thanks,
amphibian
Check your firewall, you must have RTMP/TCP port open
As a first check you should check if with firewall disabled web conferencing is working.
Then reenable firewall and check RTMP port
Romolo,
Soory it has taken so long to get back, ben real busy...Thank you for your answer.
I have the rtmp/tcp port open from beginning. Even with csf disabled or enabled video in web conferencing no work.
I guess I keep looking.
Again, Thank you
amphibian
