Webclient as App on Mac?
craigreilly
Keep shutting down your 3cx Webclient by accident on Mac... Try this:
Open Chrome:
  • type chrome://flags in Chrome’s address bar.
  • Change/set the following flag settings:
    1. The new bookmark app system - ENABLED
    2. Allow hosted apps to be opened in windows - ENABLED
    3. Creation of app shims for hosted apps on Mac - DISABLED
    4. Quit notification for hosted apps - ENABLED
    So, they look like this:
NEXT
  • Restart Chrome
  • Navigate to the page you want to run/launch as a Web Application (e.g. https://vpbxdomain.3cx.us/webclient/)
  • Click on the hamburger/'three dots menu' button in the top far right of Chrome.
    • Select 'More Tools'
    • 'Add to Applications…' or 'Create Shortcut...' (has changed over versions)
    • A small window will pop up - make changes to the Title as you like
    • Check/Tick 'Open in (Separate) Window'
LASTLY
  • The shortcut will actually be a '.app' folder with all the usually files an subfolders, like any Mac Application and...
  • the Shortcut/Dockable Icon should appear in your "User Applications" or the 'Chrome Apps' Folder within that folder:
    • EITHER '/Users/<your username>/Applications/Chrome Apps'
    • OR '/Users/<your username>/Applications/Chrome Apps'
  • Move or Copy the shortcut anyway you want, including dragging to the Mac Dock
Thanks this this thread I found on the InterWebs: https://apple.stackexchange.com/que...ps-appear-as-first-class-mac-desktop-citizens
Nicely done, Craig!
fngl
