- Joined
- Jan 9, 2014
- Messages
- 5,077
- Reaction score
- 1,096
2 PBX bridged one cloud, other on premise, everything is working fine but with webclient only we are not able to let voicemal messages over the bridge, is it a limitation from webclient or a potential misconfiguration ?
it works if i use phone call from here
and then on no answer it goes to voicemail (this is ok)
If i try to let voicemail using this menu
then call answer is (voicemail is disabled for this extension) of course it's not. and call is dropped.
have seen this menu is just trying to call local voicemail service on same pbx and not remote side as expected. The dialed number seen on screen from this menu is *43102 and change to 999 which is my VM number on local PBX
