Webclient Phone Not Connected
kugla007
I can't make and receive calls in the WebClient. I haven't used this feature before so I'm not entirely sure as to what to do.
Upon logging into the webclient it displays a red icon and says Phone Not Connected.
If I launch the Windows 3CX client then that Softphone is showing under the phones as registerd and I can manage it from the webclient.
What do I need to do to make calls directly from the browser without using any other (soft)phone? I've read that this should be possible in 15.5. SP6 version - am I mistaken?
I'm using Chrome V71.0.3578.98 and our 3CX Version is 15.5.15502.6
Hello @kugla007
To use the web client as a stand alone client you need to enable the option in the 3CX management console. Please navigate to Settings / PBX and enable the option "Enable WebRTC softphone in Web Client (Beta)". Then make sure that you are accessing the web client with the https link.
Reactions: kugla007
Thank you, that worked.
Glad i could help
aatroxadrian
