WebClient translation help needed
Nikola Paskov
New User
I need to translate webclient for a client and I found language files for it in directory:
/var/lib/3cxpbx/Data/Http/wwwroot/webclient/i18n
However it doesnt seem obvious if I make my own translation to Bulgarian:
1. what should be the file name for that translation - it should be CommonMetaResourceFile(bg-BG).xxxxxxxx.json - however looking on existing translations xxxxxxxx part seems like random string
2. where to define that new language file and language itself - I cant find any file containing current language files defined anywhere in /var/lib/3cxpbx/
Any help will be appreciated.
3CX 16.0.1078
OS Debian 9
Not sure what you're trying to do but the language of the WC can be changed within the client.
There is no Bulgarian translation included so I want to translate some of existing translations to Bulgarian and add it so that screenshot you made can provide Bulgarian among other languages.
Hello @Nikola Paskov,
May I suggest getting in touch with your Channel Manager here at 3CX to discuss the option of adding Bulgarian in?
florentrobineau
