Solved Webmeeting Add Participants error
pukkainc
When I add a participate to a webmeeting, and click the OK button, I get the following error:
An error occured while sending request to ourdomain.com:port#
How can I troubleshoot this error? The outside world can contact my domain (I can access the console).
Thanks!
Possibly using a self signed certificate? Could you kindly PM me your FQDN to perform a few checks on our side?
Ok, yes that's probably it. I have a cert but had trouble figuring out the proper format it needed during install, and ended up using the key file that was on the server. Now I need to figure out how to get my cert installed without reinstalling 3CX.
Glad to see the issue has been resolved and thank for updating the thread with your solution.
