Solved WebMeeting no longer works after upgrading to 16.0.5.611
Nils Dilau
After upgrading to latest version, it is no longer possible to create a WebMeeting from the CTI client.
When I click the icon in the client, a browser window is opened, but it is always redirected to the troubleshooting page (https://www.3cx.com/user-manual/video-conferencing/troubleshoot/).
Anyone else experiencing the same, and might have a solution for it?
Hi Nils,
Can you tell us if you have checked all the steps in the guide first?
Hi John,
Yes, I have checked all the steps in the 3CX WebMeeting Troubleshooting (FQDN etc.)
Ok assusming you have restarted the system service, and it still doesn't work, I would suggest to verify the results using the Webclient before proceeding any further.
Yes, the server has been restarted multiple times.
I have now tried the Webclient and gets the following error (see attachment) when pressing the "WebMeeting"
Hit F12 in your Chrome Browser, then right click the browser refresh button and select Empty Cache and Hard Reload.
Hi John,
Tried that, without any success. Any log file in can look into?
Not gonna be related to logs I'm afraid, can you also launch a Chrome Incognito window and try logging into your webclient from there?
What I mean is - Are there any log files I can log into at the server?
Chrome Incognito does not change anything
Hi Nils,
Please send me a private message with your FQDN and Key, I can also check a couple of things on our end
Hi John,
New to this forum, so started a conversation with you - Hopefully this is what you meant with private message
Reactions: JohnS_3CX
Yep, thanks. I will take a look and get back to you
After further investigation there was a mismatched parameter in the system that has now been corrected.
Hassan Murasan
