Webrtc does not hang up call
teemoz
We have successfully installed call center module along with webrtc, agent can log in make calls and receive calls no problem.
We are using chrome , the problem that we face is that when an agent receives the call and he do not answer and the caller hangs up , webrtc still rings . The only thing that the agent must reject the call to stop ringing. Same when you use if no answer transfer to another agent , the call is transferred to another agent but still rings at the first agent.
Any help
It is mentioned that it is compatible with all most all browser , but it is only compatible with chrome !
You have direct support on Chrome and Firefox Nightly, and for all the rest you have a plugin to support all browsers (IE, Safari, Opera,etc) https://code.google.com/p/webrtc4all/
Best regards
Thanks , we will start digging there .
Did anyone have the problem of the ringing that we are facing ?
Let me double check the user manual, I'm sure I have stated that only chrome will work. Also please if yoi can collect debug from Chrome and asterisk.
CLTedu
