Welltech WellGate-Multiple SIP Trunks
Annthonyridge
ok here is the quick and dirty .I have three analog lines connected to a wellgate in a sip trunk.I want to only receive calls and not be able to make out calls on one of the analog lines .The only way to achieve this is by creating multiple sip trunks with the lines and block the one the sip trunk from making outside calls .Can this be achieve in the wellgate 2540 .
I am not seeing any options to individually create trunk for each analog lines ..maybe i need to get a patton or a another welltech
You could get another gateway so you add the line you do not want the user to dial out from and disable outbound calling. So you will be able to auto provision both gateways and run a supported setup.
gmacinit
