What happens to M365 synced contacts when the sync is disabled?
robilletjes
Forum User
Hi!
Apologies if this was asked before already. I have a customer with m365 integration to sync contacts of a shared mailbox to the company phonebook. If I were to disable the sync, what would happen to the contacts? Would they disappear automatically or do I have to remove them manually? Thanks!
Hi!
I believe they stay there until you clear them via the bulk delete (same for CRM imported contacts.)
Reactions: robilletjes
Thank you! I'll give it a shot. If it turns out different I'll let you know :)
Yes the contacts will remain in the 3CX Phonebook until you manually delete them.
This was indeed the case. Contacts stayed untill I deleted them manually. 3cx even has a handy feature called "delete m365 contacts in bulk". Very useful. Thanks all!
KylieWilderman
