What is the best solution for specific message
Oveis
Titanium Partner
Regarding to one of our client I need to use the following message in 3CX, what is the best way to put it? They don't have IVR.
“This call might be recorded for quality and training purposes”
- As onhold music
- As Greeting message for each user
thank you in advance for your help.
Create an IVR, set Prompt = to your recording, set If no input within seconds = 1, Send call to = whare ever you want it to go
Great thanks, but the point is for any reason client doesn't want to have any IVR setup .
This IVR just plays an audio. Doesn't matter.
You could always create a CFA, that does the same thing, then you will NOT have a IVR setup, however this is the hard way
cur_cb
