What is the proper way to do a normal conference call?
L Monroe
Hi everyone, my users keep complaining about this as we find conferencing with 3CX very confusing as it seems to work different from most other systems (including 3CX itself when using a desk phone).
With using an IP phone with 3CX, as well as pretty much every other phone system I've ever used in my life, from Cisco to Avaya to Digium etc, if I'm on the phone with Bob and I want to conference in Sally, the process is the same:
  • Tell Bob I'll bring in Sally, and press the CONFERENCE button which puts Bob on hold and gives me a dial tone
  • I dial Sally's number and she answers. I can speak to her privately as long as I want.
  • When I'm ready, I press CONFERENCE again, which joins all 3 calls together.
That way I can do things like "One moment Bob let me get Sally on the line", call Sally, "Hey Sally I have Bob on the line are you free? Great!", hit conference, "Hi Bob, thanks for holding, I have Sally on the line, go ahead Sally."
With the 3CX softphone on windows or cell phone, it doesn't work like that though and is really confusing. If I'm talking to Bob and I press Conference, it clicks for a second then transfers him to 7000 which is called Conference, and then gives me a screen to add numbers. If I add numbers and press next, it just calls those people, showing our office line calling (not my DID) and then "CONFERENCE" as the call display name, so the person you are calling has no idea who you are. It also prevents you from giving a warm greeting, like "are you free to talk now can I bring Bob in?" as instead if they answer they are just now in a conference with potentially multiple people. Because of this, users almost never answer when we call them this way as they usually then say they didn't know it was us calling because it just says CONFERENCE and not our proper caller ID.
Instead the closest I can figure is doing the following:
  • Tell Bob I'll bring in Sally, and press CONFERENCE on the softphone which puts him on hold for a split second, then transfers him to 7000
  • Manually select the dialpad button to show I'm on Line 1, and now press Line 2 to get a dial tone
  • Call Sally on Line 2, speak with her, and then press CONFERENCE again to now put her into the conference and all 3 are connected
Is that the only way to accomplish this? My users are having so much problems and can't seem to figure it out or remember it. So many times when we are talking to a customer and trying to bring someone in we end up just giving up and using our WebEx bridge instead.
The reason it's so confusing is because if you're using an IP phone on 3CX, it works the way we want like my first example, it's just the softphone that does it completely differently.
What phones are you using? Which version of the PBX?
I'm not sure how to view the Softphone version but it should be the latest as it's always auto updating. 3CX is 16.0.1.273.
Oh I missed softphone.
When making a conference using the deskphone, the device is holding the conference. This will also limit the total number of participants as phones can handle only a couple of streams
When using the client (and certain deskphones ie. Snom), the conference is held by the PBX server instead, hence why you see the behavior your described.
You already found the way to add another person in the attended way, by calling from line 2.
Whe have to same problem, before it was like this. But why did you change this feature. its makes it so not user friendly.
Roman Mazur
