Where are the older logs located?
Alphabetic
3CX MVP
I'm currently trying to use the bin log viewer to determine what caused all calls in a queue to drop.
However, they only go so far back and the logging is set to 5 days.
Where can I find the older logs?
I found the logs but I was expecting to see a bldef file - Where is the path if I browse to it?
Reactions: VasilisV_3CX
Great @kieferschild,
Glad you found them. You can copy all of the BLREC files out into temp folder then copy the main BLDEF file into it as well, opening it with the bin log viewer will show you all the logs going back.
Thanks.
I seem to be missing the 3CXTunnel log from the backup
Where is this location on the Debian machine?
Log files [Global/Backup]
Nevermind, found that
Reactions: Mike Hammett
megalmazan
