Where is the advanced menu under security
DaveD
Why have Palosanto disabled the unembedded freepbx?
I now get this error
Enable direct access (Non-embedded) to FreePBX in "Security >> Advanced Security Settings" menu.
That's fine but where is the menu ??
Hi DaveD. :)
You must install elastix-security package.
# yum install -y elastix-security
Regards
Package elastix-security-2.0.4-15.noarch already installed and latest version
Next suggestion
Security Tab is there but know advanced
Logout and login again.
I made an update from 2.0.3 to 2.04.Beta5, all works fine. (yum update -y only)
I just installed there's a few minutes this package and i can access to this module without problem.
Else, i've no idea. :huh:
http://elastix-sever/index.php?menu=sec ... d_settings
Regards
Ok solved issue it appears chrome was still cache my login
Hit log out and logged in again fixed
Cool B)
CLTedu
