Which SIP Provider supports P2P Text Message with 3CX?
Akhilesh Sharma
Hello Geniuses,
Which is the best SIP provider who fully supports P2P Text message with 3CX? I tried already with Flowroute but they are asking for 10DLC registration which is only required for A2P messages. Please help me to find the best SIP that will fulfil my needs.
Thank You
Hello Geniuses,
Thank You
None exist that I know of. Every single SIP provider in the US these days requires 10DLC.
Which SIP should I go with where my 3CX clients want to use texting for their business, but those SMS will not look like a campaign instead they will reply to the text messages received on their DIDs.
Also, I am not sure if my client from 3CX is responding to a text message is falling under P2P or A2P. Let me know your thoughts.
Regardless of how the client uses SMS, every 3CX supported provider who has SMS in the US will classify the traffic as A2P and require 10DLC registration last time I checked. Yes, even to just reply to incoming messages. This is usually because the VOIP provider SMS gateways are classified as A2P.
Pick whichever provider you like, register the brand and campaign, and make sure your client know to NOT ignore the requirements or they might lose their approval status. Flowroute is fine (since you mentioned them in the OP)
SG_F7
