queeg505 Free User Joined Jul 3, 2024 Messages 7 Reaction score 2 Jul 4, 2024 #1 Hi Why is the system prompting me to upgrade the firmware to an older version? Its on 108.86.0.90 and the system is asking me to upgrade to 108.86.0.77 (see attached image) Thanks Mark Attachments Firmware.JPG 4.7 KB · Views: 2
Alphabetic 3CX MVP Silver Partner Advanced Certified Joined Jul 1, 2016 Messages 6,688 Reaction score 2,671 Jul 4, 2024 #2 Likely your firmware isnt a 3CX Supported firmware and is stock from manufacturer. Reactions: Evolute IT
queeg505 Free User Joined Jul 3, 2024 Messages 7 Reaction score 2 Jul 4, 2024 #3 Ah Ok I didnt know there was a difference, so Im advisied to go with the one 3cx are suggesting then?
Alphabetic 3CX MVP Silver Partner Advanced Certified Joined Jul 1, 2016 Messages 6,688 Reaction score 2,671 Jul 4, 2024 #4 Correct, always. Reactions: queeg505
queeg505 Free User Joined Jul 3, 2024 Messages 7 Reaction score 2 Jul 4, 2024 #5 Ok thanks for the quick reply, I will do that Reactions: GregG_3CX and NicholasP_3CX
DimitrisL_3CX Staff member Joined May 13, 2021 Messages 281 Reaction score 222 Jul 4, 2024 #6 Hello @queeg505 You can find the 3CX Supported phone firmware V20 here and for V18 here Make sure to select the correct web page according to the Version of your PBX. We always advise to have your IP phones to the latest supported firmware by 3CX as they are tested. Reactions: Evolute IT, TheodorosG_3CX and queeg505
