Wifi Works, 3G doesn't
Maximo1970
Hi, This is my first post.
I've had a look around the forum and can't find the same problem I have so here goes and I someone can help.
3CX PBX behind a firewall on a Public IP
Windows 2003 Server
HTC Desire : Android Version 2.2
3CX SoftPhone : 1.2.9
Operator : Vodafone
The issue I have is that when I connect using my mobile phone I don't get any functionality at all, other then the extension being registered ok. The status lamp is amber when connected externally and green when connected on the LAN. Using the wifi connection onto the LAN everything works as it should do.
Any help would be very much appreciated.
Thanks.
Ok you guys are going to hate me, but digging into advanced settings there is a checkbox for "use voip over 3g" that was disabled by default. Enabled it and works perfectly.
I am extremely sorry for wasting your time and really hope this thread helps someone else.
Vali_3CX said:
eagle2 said:
The tunnel port is 5090, not 8082
Orlin, 5090 is the default port, PBX admin can change it to any convenient value.
According to wireshark capture, tunnel traffic through 8082 is ok:
->Sip0REGISTER sip:192.168.254.69:5060 SIP/2.0
<-Sip0SIP/2.0 407 Proxy Authentication Required
<-Sip0SIP/2.0 200 OK
Yes Vali, but I'm not sure the default tunnel port is changed to 5090.
In the initial firewall checker (that resulting exit code 2) it was port 5060 been translated to 8082.
So, I draw the attention to this point (it might be an issue).
"Abbreviated" field names remains an open issue, I will be grateful, if you find something. I still think it could be the NAT device. Meanwhile I found this article, which means the "abbreviation" is normal:
http://www.iana.org/assignments/sip-parameters
Kind regards,
Orlin.
Kind regards,
Orlin.
Please see 2 posts above......it was the stupid "use 3g" setting under advanced in the phone.....
plz see as well the new version (downloadable here in the forum) with 3CXTunnel Support!
Finatra.us
