Wildcard certificate *.domain.ch
lucpac
Hello
I migrated V18 to V20, I did not update the certificate on the new V20, it was restored from V18 and valid till oct 2026, now the provisioning (port 443) work only if I disable "Only Accept Trusted Certificates" under Trusted certificates on the phones yealink T48U for example, maybe this is caused by wildcard certificate in V20 Only?
I also installed the intermediate certificate and the chain seems good when doing "openssl s_client -connect pbx.domain.ch:443 -showcerts"
Thank you!
Hi, please check the CA cert that you have in the Pem and ensure to also add the intermediate as well as the root certificate.
As the one you have is a root certificate
Issuer: Sectigo Public Server Authentication Root R46
Hi,you mean to put all 3 in the pem > C:\ProgramData\3CX\Bin\nginx\conf\Instance1\domain_cert_pbx.xxxxxx.ch.pem?
I already put the *.xxx.ch and the sectigo intermediate, If I understand right I have to put also the root like so:
wildcard *.xxxx.ch
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
Sectigo Public Server Authentication CA OV R36
The structure should be as follows.
FQDN certificate
Intermediate certificate
Root certificate
Hello
Thank you very much. It is working.
If I understand correctly, my problem comes out from the wildcard type of the certificate, if I use the regular one, there is no need to put the intermediate and the root certificate in the pem
Best regards
Sincerely
Luca
There is always a need for the intermediate; the wildcard does not cause it.
AshokUmmiti
