Will 3CX being adding the new Yealink T44W phone as an option.
irishrocks
I just purchased when Yealink said was brand new Yealink T44W. I wanted to test how it worked on the WIFI network. I made the assumption it would be in the list of phones for 3CX but that was a bad assumption. Do they typically take awhile to add a new phone that comes out or could I be out of luck and they will never add it?
Reactions: NickEmpireComm
Hi there.
As for now, this is not a supported device, and at the current time, we don't have any information if it will be supported.
So your only way to configure this device is manually.
Stephan Eusebe
