Will not ping but name resolution works
Climato
I have a Elastix 2.4.0 fresh install fully configured for my phones and POTS lines. However, I can not get on the internet to check for updates inside the box while any other computer on my network can connect with no problems.
Here is what I have done so far:
1. I can ping my local DNS server (windows 2003 R2), my gateway (untangle firewall:disabled) and my self.
2. If I ping google.com: PING google.com (64.126.1.163) 56(84) bytes of data. With no returned packets.
3. Here is my current configs:
Code:
[root@Elastix ~]# more /etc/sysconfig/network-scripts/ifcfg-eth0
# Intel Corporation 82566DM-2 Gigabit Network Connection
DEVICE=eth0
BOOTPROTO=static
BROADCAST=10.0.10.255
HWADDR=00:21:9b:48:83:c8
IPADDR=10.0.10.240
IPV6INIT=yes
IPV6_AUTOCONF=yes
NETMASK=255.255.255.0
NETWORK=10.0.10.0
ONBOOT=yes
TYPE=Ethernet
[root@Elastix ~]# more /etc/resolv.conf
; generated by /usr/share/elastix/privileged/netconfig
nameserver 10.0.10.5
nameserver 64.126.4.212
nameserver 4.2.2.4
NETWORKING=yes
NETWORKING_IPV6=yes
HOSTNAME=Elastix.*****************.org
I am pulling my hair as I can not figure out what is going on.
Please close this, looks like one of my config files were corrupted so after running the network set up again and changing the gateway to the correct IP It works.
On another note after running updates I have locked my self out of elastix and now only can see the FreePBX. I have posted on another board post to keep this clean.
Thanks,
Sean
CLTedu
