Windows softphone crashed by incomming call
homeshop
In addition to hardware-based telephones, we also use the Windows Softphone on a windows7 machine.
Previously, we used the 12.5 version and it worked perfectly. Never had any problems with it. However, we recently switched to version 15.5 and this version crashed regularly. Especially when we get in incoming phone call.
Windows has had all updates, and the .NET version is up-to-date
What can be done about this?
3cx softphone for windows (version 15.5) crashed randomly by incomming calls.
When the programs start i can make calls to others, but when i get an incomming call mostly of the time the first call the program works normally, but by the second call it can happen that the program crashed by an incomming call.
The softphone is installed on a windows 7 system. Complete up to date. This computer is working 24/7 of the day. The program only crashed by an incomming call, for the rest of the time it works normally...
Is this an common problem? The 12.5 version we used before works fine
I removed the program and installed again. But these was not the right solution.
hello Homeshop,
Could please tell us what exception/error you are getting after it crashes?
Yes ofcourse... When its happens i will write the error code of make an screenshot
Probleemhandtekening:
Gebeurtenisnaam van probleem: APPCRASH
Naam van de toepassing: 3CXWin8Phone.exe
Versie van toepassing: 15.5.12227.5
Tijdstempel van toepassing: 5afc1550
Naam van foutmodule: lci_proxyumd.dll
Versie van foutmodule: 2.0.31871.0
Tijdstempel van foutmodule: 5733f4be
Uitzonderingscode: 80000003
Uitzonderingsmarge: 0000141d
Versie van besturingssysteem: 6.1.7601.2.1.0.768.3
Landinstelling-id: 1043
Aanvullende informatie 1: f541
Aanvullende informatie 2: f541787e8d8af197982bfded510a65de
Aanvullende informatie 3: 0102
Aanvullende informatie 4: 01021acbcc42089589c83822390fe2f8
Lees de onlineprivacyverklaring:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0413
Als de onlineprivacyverklaring niet beschikbaar is, lees dan onze offlineprivacyverklaring:
C:\Windows\system32\nl-NL\erofflps.txt
Hi homeshop,
I would check to see if my redistributables are installed. I would even reinstall them.
Hi Roland
?!? What do you mean?
As you mean Visual C++ -so far i know- i am also uptodate with them...
Did your problem get resolved? We would have this issue occasionally; unplugging the Plantronics USB headset, plugging it in and restarting the 3CX application resolves it.
Thank you for your reply, and no, the problem still exist. This program crashed only random by incomming calls. Outgoing calls i dont have any problems with it.
We use a bluetooth wireless headset from Logilink with a bluetooth connection. In version 12.5 it works great. I don't have cables, can walk around approx. 10m from the desktop computer.
But with the new version i must restart the program different times on a day.
aatroxadrian
