Windows Store App 20.0.546.0
tdn it
The Windows Store App 20.0.546.0 update seems to have caused a few issues. The two main killers are:
  • Users are reporting that the UI sometimes doesn’t load properly:
    • Type in a number and click the call button but it doesn’t turn red to indicate a call is happening (no other indicators for an active call on UI), but the call takes place and it allows you to place many calls:
    • At the end of a call, clicking the hang up button hangs up the call, but button stays red so it looks like the call is still in progress
    • Names don’t show up next to the numbers or BLF:
    • Manager Panel is blank
    • Restarting app seems to fix it but happens randomly at next launch. Wonder if it’s connected to the next issue;
  • Can no longer consistently open 3CX from a pinned icon in the taskbar if it is not already running or if the window has been closed (e.g. only running in the system tray).
Any ETA on when a patch to address these issues will be out?
yep, its a huge bug on this version!
SupportRock
