Solved Windows Users planning to Upgrade to 16.0.6.641 beware
RichB
SOHO User
I have only upgraded one instance from 16.0.5... to 16.0.6.641 but it appears to have re-introduced the DNS issue that was found in the initial release of 16.0.5. It causes issues creating outbound calls and it was only a problem for Windows users, Linux wasn't a problem.
can you give some details, what you found exactly?
have done update on all my pbxs including on premise windows one and not seen any problem
haven't got this until now since pbxs are in.641
The excellent NickD_3CX suggested going into the SIP Trunk settings, Options tab and to change IP Mode to IPV4 which has fixed the issue for me.
Reactions: JohnS_3CX
footandankle.my3fcx.us
