Windows v15 to Raspberry Pi V16
Sangoma2009
Forum User
Hello all,
I only have a small setup of two phones and one sip trunk, I am trying to run everything on a raspberry PI, I was originally on v 15.5.1581 windows, I did a full backup and setup the raspberry pi and it went onto v16, restored the backup and everything went perfectly, however I used to use the extensions option for call recording, this option is now greyed out and I can’t see the option under the menu like I did on the old version.
Please help, this is all that is stopping me moving over to the PI to save energy.
Recording is now a pro and enterprise feature for v16. If you are on a paid license you should automatically upgrade to pro. If you are on a free license then that feature is no longer available. You can upgrade to a 4sc paid pro license for recording.
Thanks, can i install v15 onto the pi and keep using v15?
fransisco
