Wireless Conference Phone
Shadragon
Good Day,
We have an office with a glass boardroom table and no way to connect via cable without creating a trip hazard.
Can anyone recommend a wireless conference phone with battery that can be used with 3CX v15.5? This would be used for senior managers and BoD meetings so it needs to be decent quality.
We have just installed Yealink CP930W at a client site - https://www.yealink.com/products_129.html
You configure the device, the same way as the Yealink dect phones.
Note : When ordering you have to get an Yealink W60B DECT base unit if you do not have one
We have had good results with the Konftel 300wx. It is a wireless conference room phone. We have the dock for it on a table on the side of the room. If a conference call is needed, the user simply picks up the phone off the dock, places it on the table. Completely wireless when off the dock. It advertises a 60 hour talk time on a full battery charge.
https://www.amazon.com/Konftel-300wx-Wireless-Conference-Phone
9495
Hi , is this phone usable with 3cx on cloud and phone behind SBC? is it normally seen in 3CX?
Do you have user experience with the phone? is it stable and with audio quality?
The unit is local to the 3CX,
Should work on SBC, as you configure the base unit W60B with all the network configuration.
As for stable and with audio quality I do not know, but we had no complaints
Thanks Saqqara, i've already used W60B behind SBC with no problem, so if CP930W is just added to the base, it should work, you have no complaints so 2 scenarios they don't use the phone:p or use is quality enough :D
florentrobineau
