Wireless headset that can "roam"
Alphabetic
3CX MVP
Hi all
is there a solution to allow a user to walk about a building with a wireless headset?
recommendations please.
While we do support some headsets that use DECT, I imagine the range will still be limited for such a small device.
You can either use a bluetooth headset with the mobile app to roam on WiFi / LTE (probably the most cost effective and uses existing wireless networks)
Or you can look into custom solutions like adding a DECT headset to something like a Snom M900 (but you would need multiple M900 across your building, and you would not be able to control the calls)
SupportRock
