Solved Wordpress 3CX Webinars plugin
rado53
I test new 3CX Wordpress plugins.
3CX Live Chat and Talk plugin woking super. I miss the opportunity to be able to translate the plug-in into the language I use.
However, I have problems with the settings of the 3CX Webinars plugin. After installing to the Wordpress plugin, I go to the "Webinar Form". After the correct completion of all fields and press Save, I get the following error "WebMeeting Portal FQDN is not valid". In the "WebMeeting FQDN" field, I correctly specify the WebMeeting FQDN, as shown in the right column of the "Dashboard" function in the 3CX Management Console. I tested this on three different servers where I have Wordpress installed.
Where is a problem?
Rado
Hello, thanks for trying our 3CX Webinar plugin. Please check you correctly added the Webmeeting FQDN without spaces and without https:// part. Should look similar to "companyname-eu.3cx.net". If you still have problems, please send me a private message with your FQDN and I'll check what's wrong.
FYI Vezz is a 3CX employee who's just getting his forum account setup.
Sharing the FQDN with him is safe.
Thx. I'm in contact with him.
Please update the plugin and give it another go, it should be fine now.
With the help of MarcelloV, we solved the problem. Wordpress 3cx plugins needed corrections.
Thx
Reactions: MarcelloV
arming
