Solved X5U Company Name
rhwc
Hi Guys is there any way to get it to show the company name on incoming calls on the phones?
You need to populate the 3cx company address book
Yes its fully populated but it only shows the first and last name
Please note that the phones only use specific fields, namely only the ones that appear here:
If you populate these fields then the phones will be able to show the incoming caller as you wanted.
Reactions: rhwc
Thanks for the quick response John I will give it a shot :)
Reactions: JohnS_3CX
This worked btw so thank you
Diogo Maia
