XAPI - 403 Forbidden
Beats SRL
Hi everyone,
I’m having an issue with the XAPI. I enabled the service from the management panel, assigned it to the System Owner service, and copied the API key.
When I make a request to obtain the token, it works correctly, and the call to /xapi/v1/Defs returns 200 OK.
However, any other endpoint I try to call always returns 403 Forbidden.
Does anyone know what could be causing this or how to resolve it?
Thanks in advance for any help.
Can you give an example call with some verbose logs?
I have attached the script with all sensitive data removed, along with the output generated by the call.
@Beats SRL
it's still working, simple Powershell example:
Code:
$tcxurl = "mypbx.mydomain.de"       # needs port if not 443
$jsonauthbody = (@{
    Username = "100"                # 3CX user, maybe email address
    Password = "Super_Secret0815"   # 3CX user password
    SecurityCode = ""
} | ConvertTo-Json)
$LoginResponse = Invoke-RestMethod -Uri "https://$tcxurl/webclient/api/Login/GetAccessToken" -Body $jsonauthbody -Method POST -ContentType "application/json"
if( $LoginResponse.Status -ne "AuthSuccess" ) {
    Write-Host "abort: authentication not successful"
    exit -1
$headers = @{Authorization = "Bearer $($LoginResponse.Token.access_token)"}
(Invoke-RestMethod -uri "https://$tcxurl/xapi/v1/Groups?`$filter=Name eq '3CX Test'" -headers $headers -Method GET -ContentType "application/json").value
martin1176
