Yealink Custom Key for Dialing a Number and sending DTMF
Mounir1
I enabled the advanced DSS Keys for Yealink Phones in my custom template by
9973
Is there a way to define custom keys in 3CX.
At the moment I have to set the custom keys in the phones Webinterface for each phone.
This works for dialing a number and DTMF Tones by the touch of a button for our Doorcom
But using a centralized custom key (for dialing a number and Sending DTMF after connection) would be finde and better than going in each phones management interface
I was no aware of VoIP set that is able to send a group of digits as an Invite, pause, then send the remaining as DTMF, in a similar manner to a mobile phone.
Yes it works. But the key has to be assigned as a custom key. No shortdial or blf.
3cx does not have this type of key in web interface I suppose
For example in yealink web interface:
In DTMF scenario, e.g. 123$Cwc$$Cp3$456$Tdtmf$, it means when you press EDK DssKey, it will dial out 123 first, wait for connection and then wait for 3 seconds, after that, input 456 as DTMF code.
I know, that over the years, there have been requests for this sort of feature (SIP dialling, then DTMF), but wasn't aware that a set was actually capable of doing it. If no one else comes up with a solution, you might consider putting forward a feature suggestion, in the Ideas forum.
Reactions: Mounir1
As the web management does not have custom key option, the only option is customised template . This is not much good, if each phone requires different settings
As above, expanding the options for each key has been posted in the ideas section of the forum
I have a similar issue of where I need to program uRL DSS/BLF keys via yealink webpage. But provisioning from 3CX constantly wipes those settings out so I have to remove those phones from automatic provisioning, and I have to manually program each phone one by one...How do I solve this and program URL type BLFs directly in 3CX?
At the moment you can't do it directly in 3cx.
But you can set a custom template for your phones where you changed the custom key in the phone's web interface with
auto_provision.custom.protect = 1
Then your custom setting will not be overwritten.
fransisco
