Yealink SIP-T46S vs SIP-T48S
tony28
Forum User
Aside from the bigger LCD on SIP-T48S, are there any good features that I will miss if I use SIP-T46S?
T48s has no Line Keys, will this be an issue if I use it as reception's phone?
You don't need Line keys on the T48S because of the touch screen. BLF are touch instead of LED button. Other than that, the experience will be the same.
Personally we went with T46S - the physical buttons are easier for muscle memory plus it's a bit cheaper.
T48S is well designed for a receptionnist imo, nice screen where you can display your logo if you've Enterprise License and touchscreen or button depends on the ppl..
[email protected].
