Yealink T23G Advance Settings Password changed??
Andre Couture
I have provisioned a Yealink T23G phone and it is working fine.
That said, before doing the provision the Settings/Advanced Settings password was "admin" as per documentations of the phone.
Now, the phone is provisioned and this password no longer works.
I have tried the WebClient password with no luck, ...
How can I find the new password?
Hello @Andre Couture
Please note that after you provision a device the admin password changes. You can find the new password under the extension settings / Phone provisioning tab / Phone Web Page Password.
The username stays the same.
That did not work, I tried with all passwords found on the system and nothing.
I even changed the password from the page and put a very simple one and still won't allow me to login to phone settings..
Any other ideas?
Once the phone is provisioned the password set for the web interface of the phone is the one listed on the mentioned location. If you changed the password for the web interface of the phone you will need to re-provision the phone to apply the new password as the phone is not aware that the password has changed.
fngl
