Yealink T23G set ring volume to maximum and BLF 1 speed dial to 123-456-7890
big.LITTLE
Hi everyone,
We'd like to set all of our Yealink T23G ring volume to maximum and configure BLF 1 speed dial to 123-456-7890.
Can anyone please let us know how to edit the template to get it done?
the BLF is easy.
Setup on the BLF under the extension.
Not every phone model will start with 1 though.
On the volume - custom template.
So if you go for custom template - you might as well add the BLF to the template.
I do not have this model phone handy - so you will need to look at a config file/template to work it out.
On the template, I have to duplicate (or make a copy of the existing template) in order to modify it, so how can I make the phone to use the template that I have modified then?
Dame24
