Yealink T3 support
JonnyM
I know that 3CX supports all the other Yealink product ranges, but I don't want to make any assumptions regarding the new T3 series devices. Currently these aren't listed as a supported handset, is there any reason to believe they won't be supported for use with 3CX, and assuming they're going to be supported roughly how long do you think it will be before the provisioning templates are available?
Yealink does not announced when / if the T3 will be supported.
The only time you will find if the phones is supported is when it is posted on this forum
[email protected].
