Yealink T46S: How to load a custom ringtone and use it for external calls?
FredyWenger
Hi all
I have a (seems to be not) trivial problem.
We use Yealink T46S phones and want you use different ringtones for external calls.
I can load the custom ringtone (xx.wav) without problems over the web-client to the phone end set it as external ringtone.
This works without problems, until the phone is provisioned the next time.
After that, the default ringtone from the 3cx (Ring2.wav) is set again...
Unfortunately, it’s not possible to overwrite the default ring tone Ring2.wav with the custom ring tone on the phone, what would be the easiest solution.
On the 3cx, I only can set a ringtone from the default ring tones (ring1- ring8 silent and splash).
Is there an easy solution for this “trivial” problem without to start a “project” for the implementation?
Thanks for any suggestion.
