Yealink T46U Calls Transferred Disconnected
clarkhoward85
I have a remote PBX over a VPN and my T46U Yealink phone is having problems with transfers. I can put callers on hold and come back to them, but when i attempt to transfer to another extension, they go on hold, there is hold music, then they are hung up on after a few moments.
SipLeg(ads{1849}) C:54.3
12/08/2025 9:48:37.054 PMLsip{1849/54.3/Inv*[Terminated&AnswerSent]} on destroy
12/08/2025 9:48:37.054 PM~CallLeg(C:54.3); ads{1849}
12/08/2025 9:48:37.054 PM~CallLeg(C:54.1); ads{1845}
12/08/2025 9:48:37.054 PM~Call(C:54)
12/08/2025 9:48:37.054 PML:54.3[Extn:701{00000000-01dc-68b6-3ae3-882300000099}] detached from call; ads{1849}
12/08/2025 9:48:37.054 PML:54.3[Extn:701{00000000-01dc-68b6-3ae3-882300000099}]: CONNECTION ID updated: 268 => 0
12/08/2025 9:48:37.054 PMReported(Delete): SE:54.3{OnHook}
I see this in my call logs, but not certain where exactly to start with troubleshooting or what to do.
I can make and receive calls fine, it is just transferring that is the problem.
Thanks for the help.
Switch to an SBC setup if at all possible.
Strangely, the issue was related to wireguard. I fixed it by allowing just the IP from the phone into the wireguard server where the phone is located. Everything works perfect now!
tom.walker@blackcountryra
