Yealink T48G - set as default the 3CX remote phone
[email protected]
Is there a way to have my Yealink T48G go more directly to the 3CX company phone book by default?
Currently, on the T48G display from its Home Screen you press 3CX PBook, then on the second display press the 3CX Phonebook again. Seemed a little odd to need two key presses and I was just wondering if I was missing a setting somewhere.
We do not use the local phone directory, nor any other user setting in the Yealink, hence the question.
Running 3CX version 16.0.676. No changes in templates (i.e. stock config)
You are not missing anything, this is how the config / setup works
you could try using custom templates to see if you can change the function of the key. Note custom templates are not supported by 3cx
No way yet. I was trying the same last week.
Wecare_ITA
