- Joined
- Jun 13, 2017
- Messages
- 424
- Reaction score
- 256
On a new server that was installed yesterday (v16), 3CX pushed firmware 66.84.0.35 for the Yealink T48S phones at the client's location.
The location is using POTS lines from 2 providers into 2 separate Patton SN4114s. There are no issues with 3CX or the Patton devices, that info is just for reference.
We were using the first 2 DSS keys to prefix a single digit, 7 or 8 and then using outbound rules to send the call to the appropriate Patton device.
Pressing the first DSS key would prefix a 7, the user would then dial the phone number, press send and the call would go through Patton #1.
Pressing the second DSS key would prefix an 8, the user would then dial the phone number, press send and the call would fail on the Yealink phone (it was not even being sent to the 3CX server or Patton #2).
I swapped the prefixed digits and still calls using the first key (now prefixing an 8) would go through but calls using the second key would still fail.
We then moved the prefix keys to DSS keys 7 and 8 and both worked so I assumed it was a Yealink bug when using DSS key 2 for prefixing. However, this morning, the users are reporting any calls attempted with the prefix keys (DSS keys 7 and 8) are failing again. They can manually dial a 7 or 8 and then the number and the call goes through.
I'm curious if anyone else has experienced this or could test to see what their results are. I have a Yealink T52S on my desk and I've tested it without issue here.
