Yealink T48S display timeout/Inactive Level bug
bbaker73
Platinum Partner
Sharing information. Came across a bug in FW 66.83.0.55 that Yealink support confirmed.
T48S (and Yealink said 46S as well) phone settings Display>Backlight>Inactive Level>Low on the phone does not dim the display as it should. It turns the display off.
Hello @bbaker73
Thank you for sharing this information with the community. I am sure many people will come across this issue and will benefit from this information.
Just an update from Yealink:
Good day and thanks for your reply, for this issue, our R&D had analysis and will fix it, they also talked to 3CX and make an agreement that the next version for 3CX will fix this issue.
For the time plan , Yealink side plan to fix it in January 2019 if everything , then need 3CX test and verify , it depends on when 3CX will update the new firmware to their server and push to customers.
BR
Michael
Reactions: YiannisH_3CX
Thank you for the update
zipman
