Yealink T4x template - Danish Daylight Savings Time - does not work
complit
Hi all
I have discovered a typo in line #477 in yealinkT4x.ph.xml
The name should be 'Denmark(Copenhagen)' instead of 'Denmark(Kopenhagen)'.
The typo, made the phone mess up DST.
When you open the phones web interface, and changed it manually to 'Denmark(Cobenhagen)' it works fine.
I made a manual change in the yealinkT4x.ph.xml file, and reprovisioned the phones, and thes solved the issue.
Hi @complit
Please share the specific model you are referring to and the current version of firmware it is running so we can check.
Found and testet on the following phones:
Yealink SIP-T46S (Fw. Version 66.85.0.5)
Yealink SIP-T48S (Fw. Version 66.85.0.5)
Yealink SIP-T54W (Fw. Version 96.85.0.5)
But I guess that the issue is present on all phones in the template
Thanks, I have replicated the issue it will raise it with the manufacturer to resolve it in a future release.
This typo occur in all Yealink templates... and in maybe more (other) templates.
Yes noted, it is referenced in all the templates that support that location.
We will raise it with Yealink to have them all checked as needed.
[email protected].
